rebuild
Old Apr 19, 2013 | 07:49 PM
petstarfish's Avatar
Question rebuild
hey guys!
i am about to do a head gasket/ top end, any pointers? (besides read the manual a few times till tuesday thats when i am starting)
Old Apr 19, 2013 | 07:53 PM
Do not skip the step of having heads checked for flatness and skimmed by machine shop if needed. Spec is 0.002 inch, 1/2 the thickness of a page of printer paper.
Old Apr 19, 2013 | 08:38 PM
CUpgt's Avatar
I'm about to do this too more than likely. Good luck!
Old Apr 20, 2013 | 08:08 AM
DiscoJag's Avatar
While the heads are out at the machine shop, soak the lifters in Marvel Mystery oil - just don't get them mixed up, or the pushrods. Also, I replaced my head bolts. They say you can use them over once, but I wouldn't. They stretch. Of course take pictures and write stuff down while you are disassembling it. I put little lines like a clock hand on the head bolts with white paint so you can tell when you've turned them 90 degrees or whatever. I also put little pieces of tape on the plug wires with numbers on them. Best of luck to you !
Old Apr 20, 2013 | 10:23 AM
all of this is great advice. i am all about taking pictures (they help so much) also would like to post a few, maybe could help someone else. i have build many imports and 2 to 3 chevys. i dont think i will have a problem.
i would also like to tell any one to check out bma auto parts online line they had good part fairly cheap, CUpgt i would start there if i was you.
Old Apr 20, 2013 | 08:10 PM
fishEH's Avatar
Tips
1) do NOT reuse head bolts.
2) buy the In Search Of The Experience DVD. It has a great walk through of the HG job. Trust me and get it. DVD orders » in search of the experience
3) consider contacting Will Tillery about your parts. He had a great deal on new bolts and gaskets and a set of remanned heads. Just have to send your old ones back.
Old May 7, 2013 | 11:21 AM
rebuild done thanks for all the help!!
i had a check engine light come on then fixed it but i posted a list of fault code for everyone to use.
thanks again for the help!
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
Spike555
Jun 21, 2010 07:27 PM
sanchez
Aug 3, 2006 11:28 PM
