Remote door lock problem
Old Jul 7, 2015 | 12:31 PM
KAR 120C's Avatar
4th Gear
Default Remote door lock problem
Remote door lock problem. 1995 300TDi 3 door Discovery...
Hi all,
I have a problem with my drivers door lock. The key remote operates both lock and unlock. But, when I 'unlock' I have to put the key in the lock afterwards to just turn that fraction more to open the door, otherwise I cant open it.
Can anyone offer suggestions on whether this is a wear problem or a set up problem and what the likely repair required is? Also, is this a common fault on Discoverys?
Any help will be appreciated, thank you.
Michael
Old Jul 7, 2015 | 01:47 PM
TOM R's Avatar
lube and or there is a little spring that goes bad in the assembly, it can be bought at least for the 1998 d1
Old Jul 13, 2015 | 12:41 PM
archaeology_student's Avatar
It's the spring in the door lock mechanisn.
On eBay look up "Land Rover Discovery 1 Door Lock Repair Spring 5 door set" by the seller "phillipstuart33".
Replaced all of mine as the original Springs rusted and we're failing. At first I replaced the door lock actuators as I thought that was the issue but it turns out the springs were failing.
Couldn't have done it without the people on this forum helping.
jfall
May 11, 2017 11:37 PM
jsaenz
Dec 30, 2013 03:28 PM
A5scott
Aug 25, 2012 08:30 PM
larsen09
Feb 21, 2012 07:11 PM
totalperformance65
May 21, 2006 03:09 PM
