Removing Theft Alarm System
I did ask for clarity.... and no one answered.... which side of the two Blk/Rd did they tie together (or ground for that matter) The side coming out of the alarm plug or the side coming out from the dash/loom. I tied loom side together.
If you not getting a CEL prior to hitting the starter you most definitely have an ECU that's not right. Try changing it out with another, fairly plug and play but may need to have the idle reset which is an inexpensive charge.
. Tied wires on both sides now ....... Alarm as before is no longer going off
. replaced CHECK ENGINE Light (CEL) fuse. NO CHANGE
. Took out alarm control unit. Took apart. Cleaned up corrosion inside and out. NO CHANGE
. Got key to work in door. Did code starting at locked (1Unlock 5L 1Unlock 5Lock) to cancel immobilization - NO CHANGE Still no CEL, still no fire. Engine spins.... .
Need this Landy NOWWWWWWWWWW. down to only this as transportation. My VW hit a log that fell off a truck in front of me. It is THRASHED
