Replacement fuel pump issues. Please help!
I received a fuel pump from autopartswarehouse.com. They swear it's the same pump. But my old fuel pump has 2 electical plugs. This new fuel pump only has one electrical plug to fit into. What does the second plug do and will it still work. Everything else fits besides the new fuel pump has 1 plug and my disco 1 has two plugs to plug into it
I think you would have major issues. Your emissions system would not function properly.
That is why I avoid places that do not have the proper knowledge about Land Rover Parts. LR made many mid stream changes. My 97 is pre_AEL and only has the one plug, later in the same year they totally changed and those are not interchangable. Look at the identification plate under your hood for the emissions data, Regular or Advanced.
i am looking for a (i guess) single plug fuel pump 4 my 97 disco...
https://landroverforums.com/forum/di...e2/#post313142
put pictues there.. did u get whole assembly 4 118 or just pump? can you send me link? thx...
What exactly is wrong with your old pump? If the housing, float, connectors, etc are in good shape you can reuse them and just swap the pump for a late 80's Chevy pump. Just the pump will run $50-100 for just about any auto parts store. Search, there's lots of info on this method.
