replacing the re-circulation switch and the A/C switch
Old Aug 18, 2016 | 12:59 PM
azsparrow's Avatar
7th Gear
Default replacing the re-circulation switch and the A/C switch
1997 Discovery SD (I purchased it new in 1997)
Hi - I'm looking for the "tips and tricks" to replacing the re-circulation switch and the A/C switch in the A/C control unit (in the dash) - -
Also, where can I get these new switches? Both of mine have failed - I don't plan to spend $500.00 on the new complete assembly.
Old Aug 22, 2016 | 10:34 AM
jvarnadoe's Avatar
I ordered both switches new from brit-car.co.uk on advice from slickwilly1976. It only took a little over a week to receive them. I think they were around $15 USD each plus shipping.
Link to that post is here: https://landroverforums.com/forum/di...-switch-71586/
Old Aug 22, 2016 | 03:30 PM
hrhoward's Avatar
Does your blower switch work in all four positions?
Old Aug 23, 2016 | 05:04 AM
Matt927's Avatar
You need to pull the entire console to get the switches out. There is a small clip you must release from the rear of the switch. I recently pulled mine to change the small bulbs in the switches.
Old Aug 23, 2016 | 09:38 AM
azsparrow's Avatar
7th Gear
Yes - all four positions on the blower switch work -
Old Aug 23, 2016 | 10:04 AM
azsparrow's Avatar
7th Gear
Thanks for the info - I will try the company in the UK to see about the switches - I have no problem taking apart he dash - I just need to block out the time -
Old Aug 23, 2016 | 12:28 PM
hrhoward's Avatar
Asked because my a/c relay wouldn't energize and I though it was the a/c switch. It was my blower switch. Contact strip in it has to be made for a/c to work.
Most of the switches behind steering wheel didn't work when I got it. I took them apart and cleaned the wee contacts in them. Takes time and a good pair of glasses.
Jwhitfie
Oct 15, 2015 07:51 PM
preple
May 15, 2011 07:53 PM
seamonkey1
Mar 29, 2011 08:50 PM
lawson
Jun 1, 2010 12:31 PM
chrisusvi
Apr 27, 2007 01:39 PM
