Security problem!
Old Dec 14, 2013 | 12:20 AM
wbwestonbrown's Avatar
8th Gear
I fixed the tail lights with some new bulb holders.I'm having the hardest time taking tht stalk off and when you say stalk you mean the left arm thing for the blinkers right? There should only be 2 screws right? Then it should pop right off?
Old Dec 14, 2013 | 09:55 AM
abran's Avatar
Yes, left arm thing. Take the 2 screws off, then pull hard. You are going to think you broke it, but it snaps out hard. Here us a little write up I did a while back.
Good luck.
https://landroverforums.com/forum/sh...954#post431954
Old Dec 15, 2013 | 12:38 PM
8th Gear
Thanks for the help ill try to remove the stalk. Ill keep you posted (: and I got That attachment with the directions.
Old Apr 27, 2014 | 11:46 AM
James Kirk's Avatar
7th Gear
Do you still have the ecm and alarm unit? My 99 Disco 1 is immobilized, I was able to bypass the starter on the alarm unit and there is fuel at the fuel rail but, haven't figured out how to bypass the ignition system. It may not be possible to do so, I read in macassemble.com/discovery electrical troubleshooting that the alarm unit sends a signal to the ECM to immobilize and another signal to mobilize. How this can be done I'm not sure, my FOB doesn't work, I changed the battery but, cannot resynchronize due to it being immobilized. For some reason my key wont lock or unlock the doors now, was able before immobilized. Headache for sure but, I have learned alot about the vehicle through the process.
Kalev
May 19, 2014 05:05 PM
jmconnelly5
Mar 9, 2014 03:59 PM
ajfrieds
Nov 10, 2013 08:58 PM
hessie
Aug 22, 2007 05:07 PM
EASTLAND
Aug 17, 2006 08:11 PM
