So what did you do to your Disco today?
Old Sep 16, 2012 | 10:27 AM
  #731
TomOwen's Avatar
Default Mounting Plate
Originally Posted by fishEH
Jake, less work more wheeling! That thing is going to sweeter(or even sweeter) when done.
Spikey, Sorry for being abrupt. Sometimes I forget my manners. Any way to make this a Sticky?
Haven't been as busy as Jake. But I've bought a D90 brake upgrade from Lucky8, got 20' of 4ga wire and a switch for my compressor, Got a Blue Sea fuse block for the cargo area to run the compressor, an inverter, and some cargo lights off.
Did the rear window ECU bypass today.
Also cut a swithplate to mount the compressor and locker switches to.
Fish,
This plate looks great and conjurs up all kinds of iddeas for me... Question: How are you going to secure this plate to the dash? Corner screws? And will you cut out the dash behind the plate to accomodate the backs of the switches or try to fit in existing holes?
Thanks, Tom
Old Sep 16, 2012 | 08:26 PM
  #732
fishEH's Avatar
Originally Posted by TomOwen
Fish,
Thanks, Tom
Tom, as you can see from the pic there are two round and one rectangular opening already cut out in the trim. For the most part I should be able to use these, maybe having to open the up a bit. To mount the trim I'll do one of two things. I'm going to try putting a large washer on my toggle switch and use the provided nut on the front of the switch to kind of sandwich the plate. The other option will be to use four screws into the plastic trim.
Old Sep 17, 2012 | 01:08 AM
  #733
Jake1996D1's Avatar
Well today I pulled my old rover diffs and axles so I could package them up and send them off. Then I pulled my exhaust manifolds so I can prepare my truck for the Janspeed headers I picked up.
I got a set of Nitro Gears for the rear differential I plan to install this week. Once that is set up I can finish prepping the rear axle for the new toyota third member and axles. Sent out my Rovertym drilled swivel *****, a new set of front and rear stub axles to Keith to be machined for the bigger axles. I am also on the look out for an FJ80 E-locker for the front. And now that I have the funds for it I hope to have one as soon as this week...
tested out my new rear links, and well, I am going to need some limiting straps and longer brake hoses.. This design uses every inch of the 12" fox shocks.
However that did make it easier to get off of the truck and onto the bench. Rover housings and hubs even with no axles and thirds are FREAKING HEAVY.
Old Sep 22, 2012 | 01:23 PM
  #734
EricTyrrell's Avatar
Did this a while ago, but just posted it on dweb, so might as well post here too:
Not bad eh
I highly recommend steel rivnuts. These are 1/4 in. If you look at the subwoofer area you'll see LR used rivnuts.
This is 50 thou 5052 sheet. If I did it again I'd use 63 or 80 thou.
The diamonds wouldn't allow the door handle face plate or any other accessories to sit flush either.
Hurricane bolts might look and function well too.
Old Sep 23, 2012 | 11:55 PM
  #735
BD_LR4's Avatar
For the 1997 Disco 1 - I finally got my new vapor barrier for my drivers door - took the dealership 4 months to get the correct part (apparently, the warehouse had the right hand door mislabeled). Now I actually have a door panel back on my car (talk about a lot quieter!).
I also had a problem with the rear windows, took out the circuit board and found 1 joint to solder. Put it in for testing and everything worked flawlessly. Unfortunately, I din't put the board in quite right and had to take in back out. As I was trying to remove it, I broke off one of the resonator capacitors Now I need to order and resolder this part. In the meantime, the A/C will be working over time.
Old Sep 24, 2012 | 06:45 AM
  #736
fishEH's Avatar
You could just bypass the Rear Window ECU and have them working again in 10 minutes.
Old Sep 24, 2012 | 08:16 PM
  #737
CUpgt's Avatar
Installed my QT rear diff guard. Word of advice...drill the 3/8x20 BSF threaded pinion holes and tap to 7/16x14 and replace with grade 8 hardware. I also pulled the old tie rod to replace with a HD QT bar. The stocker had a nice bow to it. Ran out of light on that one. Will have to finish that up tomorrow.
Old Sep 26, 2012 | 03:43 PM
  #738
Chris Barber's Avatar
4th Gear
Default what i did to my disco today
hi all i changed the bearing on the pully for the fad bellt
when a started it up the budgie had gone but not for long as it come back in 10mins worse than it was before i had done the job when a spray maintence spray on the belts it goes so im going to get some belt spray now and try that disco 300tdi
Old Sep 26, 2012 | 08:59 PM
  #739
fishEH's Avatar
Whipped together some parts for a new spare tire HiLift mount. Still needs some paint and tweaking but I like it.
Old Sep 28, 2012 | 11:27 PM
  #740
wheelgarage's Avatar
Jake...
Are those for a LHD 4.0? I read they need to be modified to fit!
Recently, I thought I had a cracked header. I looked under and found one of the three bolts missing, connecting the header to the down pipe.
I think I will be getting the HH's (Jet'd) and do the D2's Knock Sensor deal....seems to be the easiest to deal with.
