Speedometer Not Working - VSS Reads Correct!
Old Mar 23, 2019 | 01:07 PM
_ExpeditionMan's Avatar
Default Speedometer Not Working - VSS Reads Correct!
Hey Guys,
Before everyone tells me to look at the VSS I have confirmed, using my ultragauge, that the VSS is displaying consistent and correct readings. So my question is what makes the speedometer itself fail? Is there a connector that takes input from the VSS and powers the speedometer? Basically looking for options to troubleshoot now that I know the VSS is good. Also the odometer and trip roller work perfectly. This is literally an issue with the dial indicator ONLY. 96 D1.
​​​​​​Suggestions to troubleshoot?
Old Mar 23, 2019 | 08:16 PM
cfz2882's Avatar
Wondering if the needle could be stuck-possibly by a rubber bump stop that has gone sticky...I f needle moves freely,time to start checking for broken solder joints,failed components,etc,within the cluster...
Old Mar 24, 2019 | 09:03 PM
The needle pops into action every once in a while. Any chance you have a link to an instrument cluster rebuild guide? Not sure how common this stuff is in the community. I have two spare clusters but ideally I'd like to keep the original (assuming it is the original haha).
Old Mar 26, 2019 | 12:00 PM
Going to tear into one of my spare clusters tonight and see if I can gain a better understanding of what this may look like. Anyone repair a speedo before?
boxsterrs60
Aug 15, 2019 08:36 AM
Jnj
Mar 21, 2015 04:14 PM
Matt_Attack352
Feb 17, 2014 05:44 AM
sdyver
Jul 7, 2012 11:15 PM
best4x4byfar
Apr 8, 2012 09:08 PM
