Squarness question
Squarness question
Hello,
so ive been trying to figure out the “pulling to the left” issue, pretty much changed all steering and suspension components with no luck. Today i decided to measure left and right side , hub to hub (front and rear) and found out - left side distance is 99 inches versus right side almost 100 inches.
What should I look for, Im pretty sure this much of a difference is not normal?
Have you taken it to an alignment shop yet? They will be able to tell you exactly what's wrong. Could just be front Caster out of alignment or rear caster out of alignment or a combination of both. Not sure where you live but around here Les Schwab charges like $70 for an alignment so its not that expensive.
Double check your work, check the lower link threaded end lengths that go through the frame mount from side to side. What sticks out beyond the frame mount going towards the front should be equal side to side. Make sure they're stuffed in the bushings correctly. The front radius arms are another spot for oopses.
SundayFunday
11-13-2018 12:22 PM
mbrown3039
06-22-2018 04:47 AM
