Squarness question
Old Mar 17, 2019 | 11:48 AM
emtuzas's Avatar
Default Squarness question
Hello,
so ive been trying to figure out the “pulling to the left” issue, pretty much changed all steering and suspension components with no luck. Today i decided to measure left and right side , hub to hub (front and rear) and found out - left side distance is 99 inches versus right side almost 100 inches.
What should I look for, Im pretty sure this much of a difference is not normal?
Old Mar 17, 2019 | 02:12 PM
AndyInTheLandy's Avatar
Have you taken it to an alignment shop yet? They will be able to tell you exactly what's wrong. Could just be front Caster out of alignment or rear caster out of alignment or a combination of both. Not sure where you live but around here Les Schwab charges like $70 for an alignment so its not that expensive.
Old Mar 17, 2019 | 03:14 PM
ihscouts's Avatar
Have you changed out all (at axles and frame mounts) the radius arm bushings front and back? Measure your radius arms from the frame member to the axle and I'll bet you'll find one that's longer/shorter than the other side.
Old Mar 17, 2019 | 07:10 PM
emtuzas's Avatar
Hmm actually i did change rear radius arms with terrafirma ones with corrected castor for lifted trucks. Im thinking maybe i installed the bushings that go into frame incorrectly, would that cause the issue?
Old Mar 17, 2019 | 07:20 PM
stillruns's Avatar
Anything installed incorrectly would be an issue.
Old Mar 17, 2019 | 07:21 PM
ihscouts's Avatar
Double check your work, check the lower link threaded end lengths that go through the frame mount from side to side. What sticks out beyond the frame mount going towards the front should be equal side to side. Make sure they're stuffed in the bushings correctly. The front radius arms are another spot for oopses.
Old Mar 17, 2019 | 07:24 PM
ihscouts's Avatar
Must be hung over........
Old Mar 17, 2019 | 07:41 PM
ihscouts's Avatar
By the way, the Rave specifies the Disco as having a 100" (2540 mm) wheelbase. We be short an inch if you're measuring 99" on one side.
emtuzas
Mar 20, 2019 03:22 AM
cappedup
Mar 16, 2019 03:20 PM
SundayFunday
Nov 13, 2018 12:22 PM
RA021226
Jun 22, 2018 04:47 AM
TaylorCadence
May 23, 2018 02:44 PM
