Steering Box leak
Old Jan 7, 2026 | 08:01 AM
Ozark4WD's Avatar
Originally Posted by disco96sd
I developed a leak as well - my local Landy expert - recommends keeping original equipment box and resealing - seal kit is less than $100 and time to remove - reseal - install is 2 hours so about $300 - seems like a better way to go than buying a Chinese made or re mfg. box for $100-$200 - they warranty it for 1 year
Opinions ?
I would definitely try to keep original box. I watched Britannica video on "chinese" box and it was a paper weight and nothing more...
Old Jan 7, 2026 | 01:29 PM
Mark G's Avatar
People think P/S gears are complex black boxes ....they're not. It's actually pretty simple re-do for a guy who has good mechanical skills and the factory guide. Congrats to the OP who got the top cover re-sealed.
The key unique tool you need to work on a steering gear are a sensitive inch-lb's torque wrench. Notice I didn't say Ft-lbs. Such sensitive in-lb torque wrenches used to only be available (expensive) from like Snap-on and other like companies. But now there are a lot of Chinese import options which work well. If you are re-doing a steering box, First you set the preload using the inch-lb's wrench to verify you're in the right range. Then you adjust the top screw and get in it's correct torque 'range'. Don't just go adjusting the top screw thinking you'll take out slop. I mean,... you could, just a little, on an older vehicle if you know it hasn't been tampered with. But don't just go screwing it down. That's not good. Often, from a wear standpoint, it's a lot of small wear in other components guys often replace while doing a steering box change. I took the steering gear off my '89 Chevy pickup with 275k miles, to check/reset the preload on it. Would you know it was right where it needed to be?! I know a few guys who put on all new front suspension (bushings) and new steering and had really tight steering and never touched their steering gear that had around 300k miles on it. Of course those weren't land rover steering boxes either. The point is, look at the rest of the system for wear first.
And the last thing I often advise guys/friends is: ...there will ALWAYS be some 'slop' at the steering wheel in a power steering box which can't be worked out. The reason is b/c the main shaft is actually TWO shafts. The initial input shaft is meant to move slightly with the main shaft. That little movement is designed-in and is the *valving* which ports fluid one way or the other to give 'assist' as you move the steering wheel. Unlike a manual steering box which has one shaft. Which is why a lot of the older performance cars always used manual steering ...or hybrid steering. To maintain that 'tight' feel. Older C2/C3 Corvettes, for example, GM could have designed them with a Saginaw steering box, which would have been the cheaper way to go (and many owners these days wish they would have! ...lol, but that's another story). However Zora wanted tighter performance-car steering so they went with a manual steering box with a hydraulic assist system (also used in early Mustangs).
Of course Rack & Pinion systems have changed all that.
Anyway, congrats to the OP, and good job, for getting his sealed up!!
Old Jan 8, 2026 | 07:55 AM
Ozark4WD's Avatar
Thank you Mark. It was really very doable and your directions were spot on. Biggest issue was just with one of those big four bolts, but little bit of the PB Blaster and gentle persuasion goes a long way, lol!
Old Jan 8, 2026 | 10:12 PM
Mark G's Avatar
....Biggest issue was just with one of those big four bolts, but little bit of the PB Blaster and gentle persuasion goes a long way, lol!
Sure does! (usually)
Fastercat
Jul 23, 2023 10:39 PM
lestro
Jun 21, 2021 05:13 AM
cvhyatt
Apr 2, 2021 01:47 PM
chrisusvi
Jan 29, 2009 05:54 PM
