Steering box output shaft seal replacement
Old Sep 7, 2016 | 05:12 AM
mattmannz's Avatar
Default Steering box output shaft seal replacement
I just tackled this today. Was straight forward getting everything apart.
No issues until I was seating the first of the replacement seals. I cannot get it to seat far enough home.
The second washer is thick and doesn't leave enough space to get the snap ring back in.
If I try and push the seal further in, slightly further around it pushes out. It's like there is an air lock.
Anyone have any thoughts?
Old Sep 16, 2016 | 12:05 AM
mattmannz's Avatar
No one done the seal replacement before?
Old Sep 16, 2016 | 12:37 AM
number9's Avatar
Seems like many/most folks go for another box than replace seals. Did you look in the D2 & D1 manual to see if there was any helpful info? You using some sort of seal driver?
File Type: pdf
Old Nov 3, 2016 | 09:59 PM
disco-disco's Avatar
Were you able to figure this out? I am going to have to rebuild my steering box soon. I am thinking it would be cheaper to buy a rebuild kit than to buy a new box. On that note, can you recommend a kit?
Old Jan 27, 2017 | 03:06 AM
mattmannz's Avatar
I should have posted my outcome. I had left a part of the original washer in place and therefore the new washer wouldn't seat.
All back together and no leaks. Well worth doing and quite cheap.
Old Jan 27, 2017 | 03:25 PM
number9's Avatar
Appreciate the update. Glad it went well and a cheap easy fix.
Old Oct 13, 2017 | 10:21 PM
I know its been a while but where did you get the seal kit for yours? I am ready to do mine.
Old Oct 13, 2017 | 10:50 PM
OverRover's Avatar
Lucky8 has the cheaper seal kit STC2847 > https://www.lucky8llc.com/products/s...t-pr2-allmakes
For my money I buy CORTECO Seals Only. Spendy but well worth it. L8 might offer this kit as well, but RovahFarm has it (about 7 down) > RovahFarm for all your new Land Rover Parts and Accessories
cobra29
Aug 4, 2016 01:35 AM
ATXDisco
Aug 12, 2011 06:10 AM
ljdiscovery
Feb 15, 2010 10:44 PM
Scott R
Nov 22, 2009 01:22 PM
grussell
May 12, 2009 11:51 AM
