Steering Wheel Turns...Wheels Don't
Old Jan 14, 2011 | 11:54 PM
Chris-bob's Avatar
Originally Posted by Rover Chris
may need to pop a screwdriver in the split and spread it open just a hair to help it move better.
Just don't break the tip off your screwdriver. Break it off someone else'.
Old Jan 19, 2011 | 10:09 AM
dynomite's Avatar
thanks for all the advice. pretty easy job in the end. a few tips for anyone else doing this.
1. the bolts that tighten the steering u joint (theres 4 of them, 2 per u joint) don't need to be tightened very tight. just snug. i believe this is an aluminum u joint and the threads can strip easily
2. to take the bottom u joint off (the one connected to the steering box) just loosen the bolt connected to the steering column all the way out, use a screwdriver to loosen the fitting and pull up towards the column. Then lift the column and slide the u joint off.
15 minute job.
Old Jan 19, 2011 | 10:59 AM
Rover Chris's Avatar
may consider throwing a few pieces of masking tape across the steering wheel/dash to help keep it from turning, if it turns even a little bit while the steering is disconnected your wheel will not be straight and it can be pretty difficult to line up at that point.
SuperiorCarCare
Detailing
May 16, 2014 09:12 AM
Lord Wert
Jul 4, 2013 07:52 AM
CKRVR
Oct 25, 2011 09:18 PM
calebbo
Oct 12, 2011 09:54 PM
herblatham
Mar 24, 2008 02:15 PM
