Stereo wiring help
Old Feb 27, 2012 | 12:08 PM
myquealer's Avatar
I got it working, it was fuse 6 in satellite 2, which is described as "Trailer lights, auxiliary" in the owner's manual. I was going through and testing every single fuse after running out of ideas.
Old Feb 27, 2012 | 01:43 PM
Got an amp in the rear? They may have used the trailer connector wiring harness just inside the rear door (inside the corner).
Old Mar 12, 2012 | 07:22 PM
SweetDee's Avatar
I am having the same problem, so I went to check the fuse you changed and I am completely missing satelite 2. Satellite 1 is up top, then the main fuse box then nothing underneath it. Any suggestions?
Old May 10, 2012 | 08:18 PM
bmchristian's Avatar
Question Fm adapter???
Has anybody any luck finding an fm adapter for there aftermarket head unit? I've tried E-bay and the local radio shops. Got it all wired up and sounds good but listening to the same cds over and over gets old quick lol. Radio would nice to at least hear the games on.
Old May 10, 2012 | 08:47 PM
Maybe this one is the right size - (couldn't resist)....
Old Apr 5, 2021 | 04:21 AM
ShinnyDiscoBalls's Avatar
Default What's the Blue/Yellow wire
Yes , had same.problem.
(Raido) Red to (car) Gr/Orange
(radio) yellow to (car) Violet
but now from the wiring loom (Carside) I have 2 vacant wires; a Red, and a Blue/Yellow 🤔
I'm gathering the power antenna (blue) is a moot point being antenna in the rear window. . But no ideas what purpose these other 2 serve . Radio seems to work fine (aftermarket JVC RS716)
(radio was connected to falcon)
Old Apr 5, 2021 | 11:31 PM
Icannap1's Avatar
One of the two wires will be illumination red wire (dims with the dash dimmer) make sure to tape off that wire if it grounds out you will blow a fuse. The other wire blue will be the turn on wire for the factory amplifier and the subwoofer amplifier. If you bypassed the speakers from amplifier and ran your own wiring from the radio to the speakers you will not need to connect the blue wire.
Sean Winter
Audio/Visual Electronics
Aug 6, 2017 09:30 PM
ciglesias
Jan 4, 2017 12:52 PM
E36 Phantom
Apr 22, 2012 10:39 AM
tlbslc
Nov 24, 2009 12:08 PM
lennie5936
May 28, 2008 07:54 AM
