stuck in park
Old Sep 9, 2014 | 09:02 AM
HammerFit's Avatar
Default stuck in park
Ive read all the awesome threads on this subject. It happened to me yesterday. First it was press the brake twice, it unlocked, then next start had to press brake 5 times until it unlocked. Got home no mas.
Here's my question, once I get it out of park by bypassing the switch can I leave it in neutral instead of putting back in park? Is that a battery drain or any other adverse effects?
Old Sep 9, 2014 | 09:13 AM
WaltNYC's Avatar
The key might be stuck in the ignition unless the transmission is in park. I believe there is a solenoid on the steering lock/ignition switch.
Old Sep 9, 2014 | 09:54 AM
fishEH's Avatar
Yeah, you wont be able to remove the key unless its in Park.
Old Sep 9, 2014 | 10:57 AM
MM3846's Avatar
something must be broken in my truck then bc i can take my key out in any gear.
Old Sep 9, 2014 | 01:00 PM
HammerFit's Avatar
Is this is right? The 3rd brake light came on when I did this Pressed rear defrost and brake = nothing, still locked I have no brake lights Clues?
Old Sep 9, 2014 | 02:00 PM
fishEH's Avatar
No that's not right.
A) If that's a paperclip there's paint on it preventing good contact.
B) You jumper the two terminals with the wires still attached.
Put the female connectors back on and jam the paperclip in there so its making contact. Turn the key to Pos II and press the rear defrost switch.
Also, it might not be your brake light switch that's bad. It could be the shiftlock solenoid that has failed.
Check this for the solenoid.
https://landroverforums.com/forum/di...riveway-54591/
Old Sep 9, 2014 | 03:03 PM
HammerFit's Avatar
I stripped off plastic from pclip got good connection w termials on turned on defrost button it turned orange so I know it came on key turned all the way before cranking and actually cranked it up too still same I hear the s'noid click when I press button on handle wonder if this could be fuse? nope all fuses good
Old Sep 9, 2014 | 06:49 PM
HammerFit's Avatar
Well the clip fix is not effecting it which is strange since my brake lights are not working
When I push in the button on the shifter handle I can hear the clicking sound so that tells me the solenoid is working?
Old Sep 10, 2014 | 02:44 PM
WaltNYC's Avatar
what is up with the brake lights? bulbs? connections?
Old Sep 10, 2014 | 05:27 PM
HammerFit's Avatar
It was the switch! Got one from NAPA amazingly. That mother is hard to get to if your 250lbs. I couldnt get both arms in there, had to use my head to depress the pedal!
It sure does feel good to fix these things on your own though...I did alittle dance when the shifter moved out of park!
Found out why my cruise doesnt work. The vacum hose is connected to the switch but not at the other end. I'll fix that tomorrow.
amer_qureshi
Jul 10, 2024 02:03 PM
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
felixx23
Jun 2, 2005 12:05 AM
