Stuck Thermostat?
Stuck Thermostat?
Would a thermostat that is stuck partially open cause me to run a little hot in the summer and a little cold in the winter? During the hot summer months here in STL I was running around 200 degrees F. Now, when it's colder I'm running around 174 degrees F. The temp outside has been right around freezing.
Thanks,
Thanks,
A couple of years ago I took a 2 hour ride with an open thermostat in 15 degree weather and it was nearly impossible to get heat into the cabin.
When yo change your thermostat, get a piece of 3/8' hose and siphon out coolant from top of radiator into a container. Much easier and cleaner than pulling hoses off.
powderhound
07-07-2014 10:51 AM
