Stuck Thermostat?
Old Dec 10, 2014 | 05:22 PM
jastutte's Avatar
Default Stuck Thermostat?
Would a thermostat that is stuck partially open cause me to run a little hot in the summer and a little cold in the winter? During the hot summer months here in STL I was running around 200 degrees F. Now, when it's colder I'm running around 174 degrees F. The temp outside has been right around freezing.
Thanks,
Old Dec 10, 2014 | 05:39 PM
ihscouts's Avatar
Two bolts to find out.......
Old Dec 11, 2014 | 07:16 AM
MM3846's Avatar
You probably need a radiator. I'm running ~170F in the cold weather. Stat is brand new.
Old Dec 11, 2014 | 08:10 AM
Gmacfilm's Avatar
A stuck, or partially stuck thermo will cause the engine to run hot, no matter what the outside weather is.
Old Dec 11, 2014 | 09:22 AM
Jagfixer's Avatar
When has a coolant flush been done last? Takes 15-20mins to change thermostat and make sure bleed hole is up.
Old Dec 11, 2014 | 11:10 AM
WaltNYC's Avatar
If we are talking about a thermostat which is stuck OPEN, this statement is false.
A couple of years ago I took a 2 hour ride with an open thermostat in 15 degree weather and it was nearly impossible to get heat into the cabin.
When yo change your thermostat, get a piece of 3/8' hose and siphon out coolant from top of radiator into a container. Much easier and cleaner than pulling hoses off.
Old Dec 11, 2014 | 01:35 PM
Gmacfilm's Avatar
Yes, of course. I assumed we were talking about a stuck closed, or partially closed thermostat, which causes the most problems.
Old Dec 12, 2014 | 05:56 AM
TOM R's Avatar
Where is stl ?
Either way with the stock 195 stat I would expect to run around 200 in summer
If you run a 180 stat and run 200 I would say you need to work on it
Right now I am running high 70's with 180 stat and its like 20/30* in morning, I am now running just electric fans
Old Dec 12, 2014 | 09:43 AM
MM3846's Avatar
Originally Posted by TOM R
Where is stl ?
St Louis
Old Dec 12, 2014 | 04:42 PM
fishEH's Avatar
The Lou!
HawesEA2
Dec 17, 2016 09:47 AM
powderhound
Jul 7, 2014 10:51 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
smyevich
Aug 31, 2006 01:31 PM
