Tach erratic / Alternator appears ok
Old Feb 7, 2012 | 10:19 AM
shrink's Avatar
Default Update Erratic Tach
Hey guys-
Just wanted you guys to know what happened with this in case others can be helped. Had a guy take a look at the gauge cluster and he replaced a small board in the dash and my tach is now working perfectly. As a side effect, not 100% sure if it's related my trip odometer came back to life and my fuel gauge actually reads full when I fill it up. Before it would read 3/4 tank no matter how much gas I'd put it in.
Pictures attached. The part was about $36 USD which is cheap for where I am right now.
Attached Thumbnails Tach erratic / Alternator appears ok-img_0285.jpg   Tach erratic / Alternator appears ok-img_0286.jpg
Old Feb 7, 2012 | 11:29 AM
The tie in with the fuel gauge is some electronic circuitry to do "anti slosh" smoothing of the signals for the fuel guage.
Old Feb 7, 2012 | 01:39 PM
Danny Lee 97 Disco's Avatar
Can you provide a little more specific info regarding the part number possibly and the exact location? Mine is so erratic I am 99 % sure it is a bad joint some where on a board.
Old Feb 8, 2012 | 01:45 PM
shrink's Avatar
I took the board out of the protective plastic box it was in and there's some type of part number. I unfortunately didn't see where the fellow put the part back in but I believe it was behind the gauges. If I root around in there this weekend I'll try to locate it.
Attached a better picture for you that includes the part # (or some type of part #)
Attached Thumbnails Tach erratic / Alternator appears ok-img_0287.jpg
Old Feb 8, 2012 | 08:02 PM
honda50r's Avatar
Interesting find shrink.
Looks like you have a pretty Rover-friendly pal helpin' ya out. A lot of us, I sure didn't, even knew that little board existed
Old Feb 8, 2012 | 08:40 PM
I pulled one out at the yard back at the end of November, and took this pix, thought I posted it for someone. Right out of the instrument cluster, think it is the one and only in there.
Attached Thumbnails Tach erratic / Alternator appears ok-p1120338.jpg
JPSpen
Feb 25, 2013 05:53 PM
dansgt
Mar 17, 2012 01:22 PM
Johnny_G
Jun 2, 2009 07:31 PM
azazel_18_2
Feb 12, 2009 12:39 PM
racdisco
May 13, 2007 08:03 AM
