Thermostat or coolant temp sensor? - slow to warm up
Old Nov 17, 2011 | 05:55 PM
tibyABv6's Avatar
Default Thermostat or coolant temp sensor? - slow to warm up
In cold weather car takes a bit long to heat up. When temp is at around 15F i can drive 12 miles -doing 55-60 and temp will be only 1/4 of the way.
How do i know if it is thermostat or coolant temperature sensor?
ONce coolant temp is up to where it should be - it stays there without overheating
Old Nov 17, 2011 | 06:12 PM
dansgt's Avatar
thermostat. sensor wouldnt just act up when cold.
Old Nov 17, 2011 | 06:13 PM
tibyABv6's Avatar
ok thanks...those are cheep - under $10 at advance autoparts....
On the side note - nice mustang - anything done to it?
Old Nov 17, 2011 | 06:16 PM
dansgt's Avatar
yep, cheap and easy.
Old Nov 17, 2011 | 07:14 PM
tibyABv6's Avatar
looks like autozone has them dirt cheap: $3.99 - valucraft or 6.99 - duralast
Does anyone knows if it would be beneficial to get one that opens at lower temp? OEM is 190F, autozone have some that open at 180F and 160F
Old Nov 17, 2011 | 07:31 PM
dansgt's Avatar
Run the original temp, that's where it's gonna run right and what it's designed for.
Old Nov 17, 2011 | 07:41 PM
Run to cold and your MPG will suffer.
Old Nov 17, 2011 | 08:26 PM
I tried the 160, now have the 180, mpg 15 - 17 depending on conditions, but I'm in a warm summer climate and flat for 100 miles in every direction. If you bought is used, it might not have a thermostat, some people take that out if they have an overheating problem....
kdscott100
Apr 15, 2014 12:46 AM
mattrickman
Jul 18, 2012 02:52 PM
collin Barrows
Aug 8, 2011 09:33 PM
Darover
Aug 28, 2007 03:01 PM
