thoughts on good location for coolant temp sensor?
Old Mar 12, 2012 | 09:53 AM
  #21
Yes, but how many of us rework two Discos at once while within spotting scope distance of the beach..... can't get the diff oil confused with the tanning fluids...
Old Mar 12, 2012 | 01:10 PM
  #22
ValveCoverGasket's Avatar
This looks great. Back when the engine was a whopping 3.5 liters, that fitting on the intake was part of the heater core system.
ah, good to know
was wondering why that was in there since it seemed fairly useless in this application.
Old Mar 12, 2012 | 01:11 PM
  #23
Originally Posted by slanginsanjuan
i'm using the glowshift hose adaptor in both D1 and D2. It's nicely made all metal and fits snug in the hoses.
im not real wild on inline hose adapters if there are other options, but ive certainly seen engines where adding another sensor into a metal part would be a lot more trouble than its worth so i suppose they do have their place!
Old Mar 12, 2012 | 02:00 PM
  #24
slanginsanjuan's Avatar
VCG...always follow your posts and respect your work...so let me clarify.
i'm doing what I can to keep engine temps down on the D2. I also had bad luck with the t piece of the D2 cooling system. so i thought it might be a good idea to do the inline t-stat modification (Inline Thermostat - LAND ROVER CLUB V.I.) . others have reduced temps a bit so i was looking for any extra I could get.
is that what you meant...you're not into this one? or just those adaptors kinda like you said earlier in the thread.
and sava...i'm embarrassed at the state of my two trucks for the moment. i need to get it together. i am however proud of what i have learned and keep learning.
Old Mar 12, 2012 | 03:06 PM
  #25
Danny Lee 97 Disco's Avatar
Is that a relief valve by the thermostat?
also turns out that coolant plug on this truck wasnt brass, it was steel, but no matter.
What are you referring to above?
Old Mar 12, 2012 | 07:26 PM
  #26
i think earlier someone in the thread mentioned that that plug i ended up putting the temp sensor into might be brass. it wasnt on this particular truck... it was steel.
dont think its a relief valve, Sav mentioned earlier that port was for the heater core on earlier motors...
unless you mean the part i installed? thats a temp sensor for the VDO gauge ill be putting in later.
Old Mar 12, 2012 | 07:30 PM
  #27
im just not into anything that requires cutting up the stock hoses if i can help it, more places for things to leak and i think it usually ends up looking funny
collin Barrows
Aug 8, 2011 09:33 PM
Roveroh
Aug 7, 2008 09:42 AM
louied
Jan 16, 2008 10:24 AM
willlane
Jan 4, 2008 09:05 AM
