Throttle/accelerator pipe
Old Jan 14, 2023 | 11:22 PM
Strath's Avatar
4th Gear
Default Throttle/accelerator pipe
Hi, I've just started fixing up this 96 discovery 1. I'm pretty inexperienced but it's not too big of a job. I was wondering if anyone knew the name of this pipe coming off the accelerator? My guess is that it might be the throttle housing pipe return. Is this something that can be replaced with generic piping or does it need to be more specific. Thank you for any help 😊
Old Jan 15, 2023 | 10:02 AM
JohnZo's Avatar
The broken rubber tube is for the cruise control. It works by vacuum from a pump up near the air filter box, then tees off to the brake pedal switch. There are kits available on-line to replace the tubing and tee. It only affects cruise control, so should not be a very high priority on your list. The CC electronic control module can be problematic too.
The Workshop Manual for Discos has a very good maintenance check list. I bought one for a hefty price (about the cost of a tank full) and have not regretted it. Publication Number Discovery LRL 0079ENG BB includes sections about engine and gearbox overhauls.
Looks like you have some cleaning to do. Good luck with the project!
Old Jan 15, 2023 | 08:41 PM
Strath's Avatar
4th Gear
Thank you for all the info. Yes big clean up but everything else isn't in bad shape. Will definitely look into the manual.
Old Jan 16, 2023 | 07:40 AM
jimvw57's Avatar
What you want to get is the RAVE manual. the link below will get you to the Land Rover directory for manuals.
rave manual
Old Jan 16, 2023 | 09:48 PM
CantComplain's Avatar
Yes as everyone else says, the manuals are a fine idea. I tend to like google and youtube and have survived without the purchase.
In direct answer to the other part of your question, i.e. can you replace that roached hose with generic vacuum hose?, the answer is Yes. But I'm going to guess based on the condition that there's a lot more cracked hose, and a brittle plastic T, and then whatever device it plugs into, and then the electronic control that are also hosed. As @JohnZo mentioned, it should be a low priority as these beasts are not really in their zone while on cruise control and typically have a laundry list of higher-importance tasks to address. I would hazard a guess that less than 15% of cruise controls on D1's are functional.
Post an intro and let everyone know about your new project. You'll get lots of help from very knowledgeable folks around here!
Old Jan 17, 2023 | 06:39 AM
jimvw57's Avatar
The link gives you access to the manuals, they can be downloaded as a pdf file and there is no charge, I am more of a 'dig through the manual' type of guy but then that is up to you. the manuals are from Land Rover and are the ones they use in the dealerships.
and my cruise control works fine.
Old Jan 17, 2023 | 03:32 PM
Strath's Avatar
4th Gear
Thank you for the rave manual - awesome to have it all available! Good idea on the intro post I'll put one up 😊
Old Jan 18, 2023 | 10:34 PM
LOL, maybe it's just me. I assumed everyone else's didn't work too. I think every component in mine is out.
Old Jan 19, 2023 | 06:21 AM
jimvw57's Avatar
you can swap out the D1 cruise module for a D2, they seem to work better.
https://redirect.viglink.com/?format...s-p38.90799%2F
Talulah
Aug 28, 2021 10:57 AM
Brandon318
May 7, 2020 03:59 PM
humroot
Mar 21, 2008 01:55 PM
Deb99DiscoII
Nov 1, 2007 07:46 PM
tads
Aug 27, 2007 03:22 PM
