Throttle heater plate question
Old Nov 11, 2013 | 07:24 PM
ESPN's Avatar
Default Throttle heater plate question
I noticed that recently I have been seeing some coolant loss, I think it is leaking from my throttle heater plate as the valley is wet and there is coolant sitting on the back of the motor. Is it possible to re seal it with RTV? I can only find replacement gaskets on rover's north and I don't even know if they will fit a newer intake that a 1998 4.0 has as the drawing includes an older 3.9 intake.
Old Nov 11, 2013 | 08:37 PM
dusty1's Avatar
bypassed mine for a while, after it started leaking. recently saw some gasket material at autozone. decided to try it out. it has worked out for a couple of weeks
Gasket Material | AutoZone.com
Old Nov 11, 2013 | 10:29 PM
Dusty, I LOVE your avatar, Bubbles rocks.
Old Nov 11, 2013 | 10:58 PM
dusty1's Avatar
Thanks, bubbles is a badazz
Old Nov 12, 2013 | 07:43 AM
ESPN's Avatar
Hmmm...I actually have some gasket material laying around. Guess I will have to give that a shot.
Old Nov 12, 2013 | 04:30 PM
ESPN's Avatar
Pulled the intake off today...at the throttle plate was not leaking! I have no clue where the coolant is coming from, the valley is still wet. Thermostat housing gasket was replaced with the head gaskets, I can't imagine it would be leaking? It doesn't look like it is, bottom of it is dry.
Any suggestions?
Old Nov 12, 2013 | 05:26 PM
TOM R's Avatar
Loose hose clamp, recheck torque on manifold bolts
If you reused the coolant hoses they could be dry enough that they no longer seal no matter how tight the clamp is and when they are hot and under pressure leak a smidge I have seen this several times over the years on various vehicles
There is also that short heater core hose on the pass side front it could have easily got messed up on the hg job
adolfojbonilla
Mar 13, 2016 09:59 PM
ljdiscovery
Mar 4, 2011 11:10 AM
Daymeon
Sep 10, 2009 01:12 PM
lipadj46
Jun 27, 2009 07:35 PM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
