Towing harness
#31
I'd get tubing suitable for an axle, two stub axle/hub assemblies, weld flanges to the axle tub drilled to match the stub axle and bolt the sub axles to them then fit the hubs.
#32
Eventually I'm installing a starting battery in the boot so, in support of that, I ran a #2 welding cable from the main feed at the starter stud along the chassis side rail to the rear can came up through the bottom with one of these:
![](http://i577.photobucket.com/albums/ss215/rover_driver/RoverParts/Electrical/66211-R_feeder_stud.jpg)
I then ran a #10 cable to a Blue Sea fuse block:
![Name: 5026-fuse-block.jpg
Size: 7.6 KB](https://landroverforums.com/forum/attachments/discovery-i-39/45868d1501384109-towing-harness-5026-fuse-block.jpg)
From one of the terminals on that I ran a #12 to the trailer connector. In my case I'm just charging the trailer brake battery so #12 is plenty.
What load do you expect to have? That (and the distance of the run) is how you really choose a wire gauge.
#34
#35
theswede
10-29-2015 01:05 AM
blcp86
05-06-2012 07:44 AM
twilightcall
03-06-2012 03:11 PM
nickm347
04-19-2011 02:11 PM
