Transfer Case Mounts
Old Nov 21, 2011 | 07:35 PM
AuZZZie's Avatar
Default Transfer Case Mounts
Anyone have tips/guide on replacing the transfer case mounts? One of mine is shot so I've got some new ones on order.
Hoping I can basically just slap a jack under there. Slide the old ones out, slide the new ones in.
Old Nov 22, 2011 | 04:25 PM
wheelgarage's Avatar
Keeping an eye on this post.
I was just under the Disco over the weekend, looking for that t-fer case leak. I noticed that I should change them.
Did you take a look in the RAVE. I did a quick skim, but did not find anything.
Old Nov 22, 2011 | 04:28 PM
AuZZZie's Avatar
Only thing I could see in rave was complete transfer case removal process. So not much help. Especially since they seem to really over complicate it.
Old Nov 22, 2011 | 06:25 PM
Banzai Jimmy's Avatar
I can recall removing the outside/frame-side bracket on the passenger side to swap the PS mount. I likely did the same on the driver's side, but can't recall for sure. I may have been able to raise the assembly enough to pop the mount out on the DS. It's been long enough that I just can't remember for sure.
Be sure to loosen the nut on the transfer case side of the mount before loosening anything else. You'll want that tension/grip on the mount to break that one loose. IIRC the PS one is tight to get to between the bracket plate and the body of the t-case; the DS one is easier to get to, again IIRC.
AuZZZie
Nov 29, 2011 05:56 PM
Phototone
Jun 28, 2008 02:31 PM
aublec22
Feb 7, 2008 06:09 PM
twanmedley
Jan 3, 2008 11:55 AM
BradHall
Nov 11, 2007 04:57 PM
