Transfer case problems...
Old Apr 27, 2011 | 10:52 PM
a2tz's Avatar
Default Transfer case problems...
So I have recently started trying to get some of the 60k general maintenance tasks done on my 97 Disco (Just did brakes) and thought I would try to flush the T/case and put a new RTV gasket on the view panel since it leaked some. Poor thing's had a tough life and needs some TLC.
Printed of the Rave section on it, and searched here for tips. Got the wrench I needed...half inch driver for the fill plug, and made sure I got it off fist....
So I first took the drain plug out, saw some crap on it, realized it's magnetized and those were a few metal shavings.
1st question....obviously zero is the best, but if there are a few on that plug is that ok? I took a pic of what I got off it. It really doesn't bind or grind while driving but I wasn't sure how bad is "bad".
2nd, While using the half incher to get out the drain plug, I realized it was scraping that rubber hose from that goes from that drum thing (what is that?) to up in to the car. It made a small perforation. What does that hose do...and should i just replace it/leave it/tape it/curse at it?
3rd...and most problematic for me.....Lets say it's the "top right" 10mm nut on the outer case plate came out about halfway....then just started rounding. I got all the other bolts loosened, and it so close, but now....I really don't know what to do. I was using a closed box wrench, so I don't really have anything to put on that's "tighter". I don't think I could really drill it out, it's one of the ones behind the exhaust. I sprayed the crap out of it with WD-40 to hopefully loosen up by tomorrow. So I guess my question is....given where I'm at should I just try and close the plate back up and put the other bolts on? It wasn't really leaking bad considering the rest of the car, and I didn't actually break the gasket seal on it, just loosened bolts.
I could probably get some big **** vice grips on it, which would probably chew up the head though.
Any advice would be great. I appreciate it all.
Thanks
(those are pics, if they don't work right, let me know and I'll try and post them some other way)
Old Apr 28, 2011 | 08:53 AM
kenk's Avatar
Them are some pretty good sized chunks of metal. I dont worry when I see shavings that resemble something like salt-n-pepper size. If/when you get the plate off to re-seal, check the teeth of the gears and see if any are missing chunks. If you're lucky, they will be and there not pieces of bearing material.
The drum on the t-case is a drum brake, as in parking brake. If you did't wear through to the cable to the core, I would just put a couple wraps of electrical tape to help keep out moisture.
With the bolt, I personaly would put a set of vise grips on it and just get a new one to replace it.
Old Apr 28, 2011 | 02:59 PM
a2tz's Avatar
So the cable to that drum has just a physical cable running thrugh it then right? Nothing came out when I thought it was perforated but that would explain why not.
Can I heat the bolts? Nothing down there will......catch on fire will it? (Grease or whatever). There was threadlocker blue on the view pan bolts so I thought if heated up it might help melt that a little and come out easier.
and say the metal is from the transfer case gears....I assume I woul hear grinding or binding (which I don't) at some point as they are failing so if its working now should I wrry about it? Or is that basically a sign of imminent doom?
Old Apr 28, 2011 | 08:18 PM
You will always get metal filings whenever you drain the t-case, thats why the drain plug has a magnet.
Old Apr 28, 2011 | 09:57 PM
Danny Lee 97 Disco's Avatar
You should be able to get that bolt out. There are a variety of tools for extracting damaged bolts. Vice grips may work ok. Also sears has a fairly decent extractor set that has helical "teeth" that are similar to a socket, the more you turn it the deeper it bites.
If you do try heat be careful not to damage other things. Also the longer a breaker bar or wrench you use, the more force you can develop. Use slow steady pulling force with as longt a lever arm as you can find.
PB Blaster works better than WD40 as a pentrant. Also Liquid Wrench has a good penetrating spray foam.
Dirty Dora
Mar 27, 2013 12:30 PM
HWilburn
Aug 13, 2011 09:16 AM
blondebunny
Jan 28, 2011 03:58 PM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
