Transmission issue
Old Dec 8, 2016 | 07:25 PM
dicksoutforharambe's Avatar
Default Transmission issue
Every once in a while when I put my disco in reverse it doesn't engage, so I put it in drive and inch forward and do it again and it engages. Has anyone else had this problem or have an idea if it's a sign that the trannys going? Any thoughts would be greatly appreciated.
Old Dec 8, 2016 | 10:41 PM
XCELLER8's Avatar
check the transmission fluid level first..........
Old Dec 9, 2016 | 04:50 AM
It's got plenty of fluid, probably to much
Old Dec 9, 2016 | 03:01 PM
ihscouts's Avatar
Shift linkage is out of adjustment.
Old Dec 9, 2016 | 03:42 PM
I'll look into it, thanks bro
Old Dec 9, 2016 | 09:13 PM
XCELLER8's Avatar
2x on the shift linkage too....I repaired one on my buddy's 97 that the trunion(?) ....threaded piece of the linkage was rusted,seized and wouldnt pivot ...made shifting fun
Old Dec 10, 2016 | 07:12 AM
Thanks for the advice. I'm putting a new catalytic y pipe on this afternoon. I'll do some looking around while I'm under there
Old Dec 11, 2016 | 09:38 PM
mr4x4's Avatar
while your at it check the kick down cable adjustment. Its the cable under the throttle cable at the throttle body. The clip on the metal cable should be within 1 mm of the plasic straw thing over the metal cable.
Old Dec 11, 2016 | 09:39 PM
mr4x4's Avatar
that helped me with the tranny clanking when put into drive or reverse so its worth checking just in case.
jdwilks
Dec 24, 2015 07:57 AM
summerfld
Apr 26, 2008 11:51 AM
Maximuse34
Jan 1, 2008 03:35 PM
01discosteve
Sep 17, 2007 05:33 AM
superderek3
Dec 18, 2006 12:09 PM
