Transmission Cooling line connection at bottom of transmission
Old Dec 23, 2015 | 08:52 AM
jdwilks's Avatar
Default Transmission Cooling line connection at bottom of transmission
So got a puncture in the rubber hose for the transmission cooling line. Picked up a used one and for some reason having issues getting the connection at the transmission to secure. This is the one that connects at the bottom so the one that is easy to access. Should be simple I would think and other one was easy to remove. Rubber o-ring is there (have a new one) but seems as if either I have a bad angle going into hole in transmission or something else as I cant get it far enough up into the transmission to get any threads on the fitting to take. Also seems the fitting is off angle as I can see more of the threads towards the front of the car then the back. I have tried pushing on the line fairly hard towards front of car but maybe I am just missing something. Pretty sure I have it routed since there are not many options and just followed how the old one was installed. Was going to try the old one sometime today to see if maybe something off on the newer one I got as well. Doing some research it sounds like I might have been able to repair the old one as well so if it fits I may go that route just not sure exactly what I need to do
I guess looking for an advice...Thanks
Old Dec 23, 2015 | 11:44 PM
jdwilks's Avatar
Just to follow up in case anyone comes across this. I actually found that the used part i order had a lip on the outside end. Once I filed it down it slipped in pretty easy and was able to tighten up
Old Dec 24, 2015 | 07:57 AM
abran's Avatar
Thanks for the follow up. I had no real advice except try again, so I thought it better I didn't comment at all.
NoogaRover
Apr 3, 2015 06:10 PM
Hawk99
Mar 3, 2015 12:13 PM
Echoman
Oct 8, 2014 10:10 AM
twmj1953
Aug 8, 2010 06:53 AM
bigun
Oct 7, 2009 04:59 PM
