Transmission oil dipstick...
Old Jan 20, 2026 | 07:54 PM
Externet's Avatar
Question Transmission oil dipstick...
Hello all.
If the full level (P, after shifting, idling) is at the lower lip of the shown threaded tube stub attached to the pan front, is the stick full mark supposed to be exactly at that level when fully inserted ?
Isn't then the stick end horizontal ? How does it show properly ?
The 'full' mark notch on the stick is 32mm away from the tip of the stick. How does it work ?
Last edited by Externet; Jan 20, 2026 at 07:58 PM. Reason: Image does not stick, 'Go advance' not available.
Old Jan 22, 2026 | 10:48 PM
JohnZo's Avatar
I don't think the dipstick extends into the horizontal part of the tube. It stays up in the rising portion.
Old Jan 23, 2026 | 07:24 AM
Externet's Avatar
Thanks. As some people have transplanted the oil pan from a Disco 1 to Disco 2 to gain the dipstick 'feature'; I have to believe the pans are the same, differing in the threaded stub to attach the dipstick tube, and the 'full' level being the same as the lower lip of that stub out of the pan.
Seems to me that the 'full' notch if in the rising portion would be way higher than the oil. Cannot get it how it works.
Old Jan 23, 2026 | 11:33 PM
JohnZo's Avatar
Well, for sure it does work. I guess, if the dipstick stays up in the rising portion, then the full oil level is higher than the top of the stub. Maybe try measuring the length of the tube to compare to the dipstick length.
bdruhan
Jan 12, 2026 09:50 PM
Tartan
Apr 17, 2025 09:16 PM
mtsuji90
Oct 24, 2022 02:18 PM
osolupo
May 17, 2010 12:57 PM
chargersfan
Aug 25, 2007 12:22 PM
