Trouble lights
Old Nov 18, 2012 | 11:31 AM
JPSpen's Avatar
Default Trouble lights
OK.. My ABS and SRS lights are on constantly.. AND the Right hand side of the SRS light is blinking...Horn works...
ABS light stays on all the time and I've tried jumpering 5 & 15 on the connector to get a blink code.. Nothing...
NO Check Engine light ever.. I'm assuming it's burned out or has been pulled..
So, I'm looking for input on troubleshooting... A relay missing or fuse on the ABS ?
What about the SRS.. Strange that the right hand side is flashing...
Thanks for any help anyone can offer... I'm just really getting started on these issues so I'm looking for tips..
Thanks
John
Old Nov 18, 2012 | 02:43 PM
zer0Point's Avatar
On my 98 Disco, the ABS light is illuminated as well. The computer is reporting code P1317 "rough road signal line permanently at ground or open circuit". You could start there.
Old Nov 18, 2012 | 08:03 PM
From RAVE -
ABS Warning Light
The ABS warning light receives battery voltage with
the Ignition Switch (X134) in position II. It is
grounded by the Anti–Lock Brake System ECU
(Z108) or the ABS Warning Relay (K103) in the
event of an ABS problem.
and
SRS Indicators
The SRS Indicators are controlled by the Air Bag
Diagnostic Control Module (Z151) and the SRS
Indicator Control Circuit of the Instrument Cluster
(Z142) to indicate SRS System faults.
So this means those lights come on by command of a module, not a plain switch to ground, like oil pressure. See page 123 and 127 of 556 pages of the 1996 D1 electrical circuits guide, in the RAVE. There are dual indicators in the SRS light. Your off the shelf code scanner will not read the ABS or the SRS modules, will need a dealer level or very advanced shop unit.
OffroadFrance
Nov 27, 2014 04:42 PM
Alex_M
Nov 24, 2014 07:03 AM
Matt_Attack352
Jan 13, 2014 09:55 AM
01d2Jeff
Nov 19, 2011 10:52 AM
drakenkade
Dec 19, 2010 01:28 AM
