Unusual question thermostat
Heed the warnings above and keep a very close eye on your coolant level and of course your temp level to the extent that is possible with the dash gauge.
You may get through the winter months without incident, and you should remain vigilant as the weather warms up. (although it looks like the temps in Vancouver don't swing wildly summer to winter)
ultragauge makes a decent product that gives you a **** ton of obd2 information that is highly intuitive and accessible while driving so you can keep an eye on your temperature real time, with some accuracy. there are some bluetooth obd2 readers that work with an iPhone or Android app, but haven't heard much about those either way
I'm assuming you mean 88c, 88f would be open much of the time even without the engine running.
88c is what you want if made in Europe. It seems Made in USA thermostats are marked with the temp at which they start to open. UK thermostats are marked with the fully open temp.
Land Rover specifies it should be fully open at 88.
If in doubt, test it in a pot of water with a thermometer. Suspend it with a wire so it's not touching the pan so you get an accurate reading.
A US thermostat like the Stant I posted start to open at 180f (82c) and are fully open at about 190 (88c) or a little less.
Cowtown1411
05-01-2012 09:37 PM
