Unusual question thermostat
Old Nov 14, 2013 | 08:08 AM
WaltNYC's Avatar
Originally Posted by fishEH
Also, people don't just remove the Tstat for no reason. It's a $15 part at best and takes no more effort to replace than it does to remove the old one. The most common reason the Tstat gets pulled is because the truck is running on the hot side.
Very true...but paradoxically may actually make matters worse. If coolant passes through the radiator too quickly it doesn't have the opportunity to dissipate heat sufficiently.
Heed the warnings above and keep a very close eye on your coolant level and of course your temp level to the extent that is possible with the dash gauge.
You may get through the winter months without incident, and you should remain vigilant as the weather warms up. (although it looks like the temps in Vancouver don't swing wildly summer to winter)
Old Nov 14, 2013 | 08:24 AM
ajnolin's Avatar
ultragauge makes a decent product that gives you a **** ton of obd2 information that is highly intuitive and accessible while driving so you can keep an eye on your temperature real time, with some accuracy. there are some bluetooth obd2 readers that work with an iPhone or Android app, but haven't heard much about those either way
Old Nov 14, 2013 | 10:00 AM
VenVen's Avatar
4wd High
ok thanks guys!! I have really good deals for part the t-stat coat me 10$ so I was changing it at the same time as flushing the coolant! I emailed the old owner to see the reason he removed the t-stat!
thanks for all the answers
Old Nov 14, 2013 | 01:47 PM
antichrist's Avatar
Is it an 88c (if from the UK) or 180F (if from the US) thermostat?
Old Nov 22, 2013 | 09:08 AM
VenVen's Avatar
4wd High
It is an 88f!! Am i better of with the 180f??
Old Nov 22, 2013 | 09:09 AM
VenVen's Avatar
4wd High
Originally Posted by abran
Just to clarify, the spring side of the t stat goes into/towards the block. Also if there is a small hole/small hole with bobble thingy that goes at 12 o'clock top position. Have fun
Thanks! That was exactly the answer I was looking for!!
Old Nov 22, 2013 | 10:49 AM
antichrist's Avatar
I'm assuming you mean 88c, 88f would be open much of the time even without the engine running.
88c is what you want if made in Europe. It seems Made in USA thermostats are marked with the temp at which they start to open. UK thermostats are marked with the fully open temp.
Land Rover specifies it should be fully open at 88.
If in doubt, test it in a pot of water with a thermometer. Suspend it with a wire so it's not touching the pan so you get an accurate reading.
A US thermostat like the Stant I posted start to open at 180f (82c) and are fully open at about 190 (88c) or a little less.
route66lives
Apr 26, 2017 04:00 PM
DonRW2007
Sep 26, 2012 01:55 PM
Cowtown1411
May 1, 2012 09:37 PM
Cnydisco99
Feb 24, 2011 11:03 AM
kinden
Oct 16, 2009 02:30 AM
