Well got the swivel back together but
Old Dec 9, 2010 | 11:00 PM
Garrett's Avatar
Default Well got the swivel back together but
Got all the parts I needed and put it all back together tonight, fun.
While it was out I found a package of AllMakes one shot swivel lube in the back and a new CV/Half shalf. Put that in because the old shaft CV joint was rusty and very hard to move
Anyway I get it all back together with all new bearings, new caliper, pads etc etc.
Put the wheel on, tighten it down and I grab the wheel at 12 and 6 and I still have a tad bit of movement. I'm thinking SOB I put a junk swivel in it. So I have my buddy move the wheel and I look at the ball and it's got zero movement in it so I'm semi relieved but now wondering wtf is loose.
Any ideas?
Thanks.
Old Dec 9, 2010 | 11:37 PM
kenk's Avatar
Wheel bearings? How did the stub axle look- if it has groves worn in it where the wheel bearings ride, it will allow slop even though the hub nut is tightened to spec.
Good way to tell- have someone press the brake pedal while you try to move the wheel at 12 and 6 o'clock. If it does not have wiggle then the problem is in the hub/bearings/stub axle. If you can get play with the brakes on, then it's a swivel ball/steering knuckle problem
MrFlea1
Dec 5, 2011 08:17 PM
rlrigsby
Apr 10, 2010 04:58 PM
mcrw
Jan 29, 2009 07:48 PM
adowgiert
Jan 22, 2007 06:02 PM
