Where is this oil coming from
Old Feb 28, 2013 | 10:32 PM
Rock Sing's Avatar
Default Where is this oil coming from
What is going on? Where is this motor oil coming from? What is going bad? It is on the front of the engine right behind the water pump. Rock_Sing's Story by Rock_Sing | Photobucket
Attached Thumbnails Where is this oil coming from-2013-02-26-14.41.14.jpg   Where is this oil coming from-2013-02-26-14.41.05.jpg
Old Feb 28, 2013 | 10:36 PM
CUpgt's Avatar
Prob the end seal on the valley pan. I had some still there from when I ran Mobil 1. Cleaned it last weekend and yet to have it build back up. Hoping using rotella has solved that problem
Old Feb 28, 2013 | 10:38 PM
greenharoguy's Avatar
Cant say for sure, because Im not there, but if I were you I would check your intake manifold gasket. I had a leak there on mine before I did my heads, and during the process I installed a new intake gasket and it was fixed. Hopefully someone else will chime in though for another thought or two on it.
Old Feb 28, 2013 | 10:55 PM
CUpgt's Avatar
Valley pan gasket and end seal = intake manifold gasket and end seal
Old Feb 28, 2013 | 11:23 PM
Oops, didnt even see your post there when I replied. Would have just left it at that.
Old Mar 1, 2013 | 12:11 AM
Also called a lip seal sometimes. Bolt in center to snug up.
Old Mar 2, 2013 | 02:01 AM
Walko327's Avatar
do like buzz said snug up the center bolt there. but best fix would be take the time and go ahead and do whole new valley gasket. FYI rotella on sale at oreilys 5$ off a gallon. 5 gallon bucket 64$ great deal. not sure how long the sale is though.
wkburns
Oct 27, 2013 08:53 PM
Rock Sing
Mar 1, 2013 12:35 AM
srockrae
Sep 3, 2012 06:08 PM
bangkuaidiscovery04
Feb 7, 2010 09:31 AM
johnboyairey
Oct 15, 2008 06:16 PM
