Whining sound
Take the fan belt off and run it for a minute to see if indeed it is a pulley. It could be any of the alternator, tensioner pulley, water pump, PS pump, or A/C compressor. Tensioner pulley bearing is easiest so start there if you can't tell.
https://landroverforums.com/forum/di...08/#post702268
If it’s a windy type of sound, like a bunch of air being sucked or blown, then your fan clutch is bad. If it’s more of a grinding sound, it’s a bad pulley bearing. My A/C compressor clutch bearing made that noise until I removed the pulley, hammered out the bearing and replaced it.
If you can’t tell where it’s coming from, remove your belt and spin/wiggle your pulleys around to see if one’s a little loose. they should all spin smooth and straight.
