Whining sound
Old Aug 23, 2021 | 07:12 AM
Birminghamrover's Avatar
Default Whining sound
I have a 96 disco 3.9 efi with auto box. When the car has reached temperature and comes to a stop a whining sound starts up . Any idea what this could be ? The sound is quite loud.
Old Aug 23, 2021 | 12:24 PM
Ok the sound is definitely coming from something on the fan belt . Will have a look into where the weekend. Any tips on diagnosing which pulley is the culprit would be much appreciated! Cheers !
Old Aug 23, 2021 | 03:43 PM
WaltNYC's Avatar
Take the fan belt off and run it for a minute to see if indeed it is a pulley. It could be any of the alternator, tensioner pulley, water pump, PS pump, or A/C compressor. Tensioner pulley bearing is easiest so start there if you can't tell.
https://landroverforums.com/forum/di...08/#post702268
Old Aug 23, 2021 | 07:08 PM
ononomos's Avatar
If it’s a windy type of sound, like a bunch of air being sucked or blown, then your fan clutch is bad. If it’s more of a grinding sound, it’s a bad pulley bearing. My A/C compressor clutch bearing made that noise until I removed the pulley, hammered out the bearing and replaced it.
If you can’t tell where it’s coming from, remove your belt and spin/wiggle your pulleys around to see if one’s a little loose. they should all spin smooth and straight.
Old Aug 24, 2021 | 12:36 AM
Thanks for the advice . I will update when i have done something !
Old Oct 20, 2021 | 12:39 PM
Water pump it was , really squeaky when i turned it after taking it off . Thanks for the replies , sorry for the long feedback . Next thing now is the snapped rear shock 🤣
evan.byron@gmail.com
Aug 2, 2021 01:22 AM
cornbreadj
Dec 26, 2014 02:47 PM
rat2
Jun 23, 2012 08:16 PM
blcp86
Aug 29, 2009 01:22 PM
G3
Freelander
May 11, 2007 11:03 AM
