won't go past idle
Old Feb 21, 2011 | 01:34 PM
Danny Lee 97 Disco's Avatar
Are you just wiggling the wire? If it is loose, you need to figure out why and tighten it up. It will never run consistently with a wire loose for some important function.
And you should change the fuel filter also if it is not fresh.
Old Feb 23, 2011 | 12:58 PM
rover11's Avatar
Originally Posted by jafir
It could be your cat. My 96 acted this way. Turns out one of the cat had come apart inside, and the honey-comb like material would turn sideways and block the exhaust flow. It wouldn't rev over like 1800... If you looked at the cat while trying to rev it up, it would eventually start glowing red. Then conditions would change... a bump in the road, who knows... and it would be fine. I went to a muffler shop and had it replaced with a weld in, and problem solved.
You were right. I took the Discovery to a mechanic that specializes in Land Rovers. They looked at all the wires and said they were fine. There was a leak in a vacuum hose, they replaced that. They also reset the computer. I guess the whole reason I had the problem to begin with is there is an issues with exhaust. I was in my wrangler so I could not hear what the mechanic was saying very well but it was something with the back pressure and the exhaust. The computer kept trying to compensate screwing everything up. They should have it done today or tomorrow.
On the positive note the engine looks like new and everything else looks good.
Old Feb 23, 2011 | 03:27 PM
jafir's Avatar
Good deal. It's always good to hear back about what finally fixed someone's problem.
Old Feb 23, 2011 | 06:27 PM
rover11's Avatar
Lets hope that fixes the problem. $871 later...
Old Feb 24, 2011 | 07:59 PM
rover11's Avatar
Picked the Rover up today. It drives perfect! Now to fix all the cosmetic issues.
I Brake For Cats
Aug 24, 2017 02:00 PM
Grlica
Dec 11, 2013 11:49 AM
Paul Aspen
Nov 4, 2013 02:10 PM
NickDII
Jan 23, 2012 12:00 PM
Robwsup
Jun 27, 2010 03:38 PM
