01 D2 coolant issue
Old Feb 7, 2013 | 12:21 PM
roverman2010's Avatar
Thumbs up
OK. As long as you know that it won't run that fan unless AC is on and outside temp is above 82F. So not quite that warm by the sea wall today.
Yes ac on and also warmed up the air sensor with a warm rag, ecu somehow is not telling the fan to come on. now does the ecu look at both the amb air temp sensor behind the grill and the maf temp? for the ac .
thanks
Old Feb 8, 2013 | 01:51 AM
I would guess that you could unplug the coolant sensor on top of the engine, and attach a 1000 ohm resistor to the connector. This would look like a high temperature, and should make ECU call for electric cooling fan.
nate2k5
Jun 3, 2012 05:49 AM
Kingmarine
Feb 26, 2012 09:27 PM
tunernewb92
Oct 20, 2009 07:15 PM
dms98e
May 9, 2008 08:36 AM
