01 Disco II Head Gasket Job
Old Mar 27, 2013 | 12:08 PM
pinkytoe69's Avatar
Strap wrenches...
Are the plastic w/ rubber loop style good enough or do I need to spring for metal w/ nylon loop?
Old Mar 27, 2013 | 12:27 PM
drowssap's Avatar
what exactly are you trying to remove on your p-38
Old Mar 27, 2013 | 12:45 PM
pinkytoe69's Avatar
No, I'm doing HG's on a d2. I'm using a Bosch p38 walkthrough cause I couldn't find a d2 one.
This walkthrough said I could leave the fan on. The p38 ps pump pulley stays on as well.
Didn't realize the differences til after serpentine, tensioner, alternator, and a/c were removed.
As such, I have to get the fan and ps pulley off without the serpentine on.
Old Mar 27, 2013 | 01:22 PM
slabrat's Avatar
Originally Posted by Cliff
The advanced auto near me rents out a fan wrench set basically for free. The charge $50 or $60 on your card then refund your card when you return it.
I used that a strap wench to slap it loose.
THe Fan on my disco is 32mm
Make sure the set from AA has a 32mm in the set. The smallest one in the set they "loaned" me was 36mm . I ended up buying one on Ebay.
Old Mar 27, 2013 | 01:35 PM
drowssap's Avatar
no need to remove the power steering pump for head gaskets.
Use the plastic one the fan not on that tight but I do thing there is thread locker on it.
Old Mar 27, 2013 | 01:50 PM
pinkytoe69's Avatar
Don't i need to take the pulley off in order to get to the bottom bolts holding the a/c bracket on?
04DiscoMike
Nov 17, 2014 06:48 AM
a-rod
Sep 21, 2013 09:33 PM
FlyingZebra34
Apr 25, 2013 08:04 AM
GARovee
Feb 11, 2012 08:00 AM
fsufan8
Aug 5, 2005 03:48 PM
