02 LD Disco II SE won't start
Old May 21, 2022 | 01:15 PM
crazycracker's Avatar
Default 02 LD Disco II SE won't start
I went to turn on my Disco II this morning. But when I turned the key in the ignition everything came on as per usual. The radio and lights but not the engine no sounds, no movement dead except for dash lights. I turn it again, same results. I know it's not the battery as the electronics work. Just the engine isn't responding.
Could this possibly be Ignition Cylinder, Alternator, or some kind of unseen third issue?
Old May 22, 2022 | 07:32 AM
mollusc's Avatar
Do your brake lights come on when you put your foot on the pedal? Does the readout on the dashboard correctly align with the position of the gearshift lever?
Old May 25, 2022 | 01:56 AM
JUKE179r's Avatar
Remember, a battery can have low cold cranking amps for starting regardless if it has/shows good voltage.
Also really check the battery for loose or corroded connections.
Old May 26, 2022 | 12:46 PM
Motorhead1's Avatar
starter motor could have died also.
timpugliese
Jan 17, 2015 08:34 AM
averagejoe
Oct 25, 2013 02:08 PM
jerdani_303
Apr 7, 2013 06:16 AM
mwood2121
Sep 7, 2010 12:22 PM
SOONERRN
Apr 28, 2008 11:06 PM
