03 Discovery Key Fob flip, Upgrade (Valeo)
Old Apr 20, 2013 | 02:36 PM
  #41
dparham's Avatar
Originally Posted by eitydeuce
What mod did they do at the hardware store? just in case i run in to the same thing.
no mod, just took it apart and gave key cutter just the blank that came with it
Old Apr 20, 2013 | 03:22 PM
  #42
dparham's Avatar
Originally Posted by coors
I had a simialr thought. Will any hardware store capable of cutting keys be able to cut the one we all just ordered?
Mine did I just took a little screwdriver and removed the blade as per his instructions...
Old Apr 20, 2013 | 03:27 PM
  #43
dparham's Avatar
I may be double answering but Im doing it just to make it easier lol I took my key blade out of the remote ( wiggle n pull ) then took apart the new key controller,removing the blade.. gave both to the hardware key cutter and BAM 30 seconds DONE! was a little pain to get spring working and also take new controller apart slowly sow spring doesn't fly away lol and then just watch how it came out and put back same way... I think I kind of rotated the back part on spring to create spring tension... thank GOD we dont have to do this when doing our suspensions! hahaha
Old Apr 29, 2013 | 08:30 PM
  #44
caymandrew's Avatar
Got mine, easy breezy:
The trick is to just rotate the top part one full revolution while connected to the spring and then push the whole thing together. That'll create enough tension to spring the key out like a switch blade
Old Apr 29, 2013 | 08:45 PM
  #45
coors's Avatar
Did you have success getting it cut?
Old Apr 29, 2013 | 08:46 PM
  #46
caymandrew's Avatar
First on my list for tomorrow but already scouted out the key cutting op at home depot and doesn't look like it'll be a prob. I'll find out for sure tomorrow!
Old Apr 29, 2013 | 09:00 PM
  #47
coors's Avatar
I'm going to caution you. Read the other thread about the horror stories most of us encountered trying to get this key cut. You're better off going to a locksmith than a teenager running the key cutting machine at depot.
Old Apr 30, 2013 | 12:35 PM
  #48
caymandrew's Avatar
Took your advice and just went straight to the locksmith. $2.40 cents and 3 minutes later the key was cut. I did have to remove the blank from the housing for the guy but that was it.
Old May 8, 2013 | 01:28 PM
  #49
cosmiccharlie's Avatar
I got my second key yesterday. Had it cut today and it works great. Guy had to go at it a second time to make a couple of the cuts deeper, but it works! Find an experienced locksmith and they shouldn't have a problem.
Old May 8, 2013 | 01:44 PM
  #50
ZGPhoto's Avatar
Haha I still haven't gotten mine cut, walking around with 2 fobs has been a pain.
cappedup
Jun 9, 2015 06:04 PM
tsuami1
May 30, 2014 01:18 AM
Street Wolf
Apr 14, 2014 04:11 PM
Navy_Jak
Jan 5, 2010 11:07 PM
red rockett
Mar 6, 2008 02:53 AM
