04 d2 chirping while moving
Old Apr 12, 2021 | 03:33 AM
The Deputy's Avatar
Whack it with big hammer, using a block of wood in between. Hit yoke solidly and sharply, it will eventually move.
Couple other thoughts, since you've not greased the shaft before, by the sounds of it...you may want to check your fluid levels, especially transfer case and transmission. Read up on transmission fluid check/change, vehicle has to be running to check fluid. If you check it while it's not running, you'll lose about 3 - 4 quarts of fluid so beware of that. Transfer case is pretty straight forward, plug is located just to the side or partially behind parking brake drum assembly. Yeah, it can be a pain getting a tool in there to loosen it, but it's doable.
Old Apr 12, 2021 | 04:24 PM
XRAD's Avatar
just drop one end of driveshaft in question and use the shaft leverage to pry loose the other end....
Old Apr 24, 2021 | 06:05 PM
Triddell62's Avatar
Yep, still no luck
Old Apr 24, 2021 | 06:57 PM
Triddell62's Avatar
Finally got it off, the double u joint is stiff and the chirping is gone
Old Apr 25, 2021 | 02:09 AM
The Deputy's Avatar
Good news, and thank you for finishing up discussion with results. This topic may come in handy for the next guy or gal with similar noise.
Now, don't forget that transfer case fluid check...like 99% on the Dll owners out there. I've owner four Dll's...and all four were empty or close to it.
CoachTodd
Nov 17, 2023 08:25 PM
Theodore L
Oct 14, 2015 08:46 PM
DiscoCam
Oct 10, 2015 11:52 PM
evansjoem
Sep 18, 2014 11:56 AM
Jared9220
Aug 20, 2014 10:22 AM
