04 Discovery II Head Gasket Replacement Job First Issue
Old Mar 28, 2011 | 10:20 PM
rcrosby's Avatar
Default 04 Discovery II Head Gasket Replacement Job First Issue
It started last week with lots of white smoke and loss of coolant. I decided to tackle the job myself. I have the gasket set, the bolts and a couple odds and ends on order.
I ran into my first hurdle. While removing the upper intake manifold I followed all of the steps but I can only see 2 bolts where the coils attach and I removed those. I can see a 3rd on the passenger side way in there but nothing on the drivers side. Everything else is loose but I am getting hung up there.
Any tips?
Old Mar 29, 2011 | 05:43 AM
drowssap's Avatar
on my 4.0 the were four bolt holding coil pak two up high easy to see and 2 way down low. Spray some air or carb. cleaner down on the drivers side and see if you dont find another bolt.
Cassidy Bodle
Nov 20, 2013 10:56 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
jljde
Mar 8, 2013 07:23 AM
echomike
Dec 7, 2010 05:31 PM
jayv
Oct 7, 2010 09:15 AM
