04 Discovery wtf
Old Aug 31, 2016 | 03:57 AM
  #21
batard's Avatar
Do the diagnosis properly, which is easy. If it turns out you need a starter motor, go out and get one. Don't make assumptions about what's wrong and blindly throw parts at it.
Old Aug 31, 2016 | 03:09 PM
  #22
OffroadFrance's Avatar
Originally Posted by batard
Turn on the headlights or the cabin lights and see if the lights dim at all when you turn the key. Then follow the steps in this video and report back: How to troubleshoot a no crank problem (94 Toyota Celica) - YouTube
Batard, good vid and learning curve for anyone with non starting woes. I'm not sure whether it's you and your lad but whatever, he probably learned a lot then.
PS. ....................some great trick electrical diagnostic kit also, wish I had similar kit to play with.
Old Aug 31, 2016 | 03:46 PM
  #23
B846B's Avatar
I have an 04 and I experienced something similar last week after installing a winch and bumper. Turned key and nothing, lights in dash went out, click from starter. Wiggled the cable and it would start. Tighten everything up and it would fail to start again. My problem turned out to be a bad connection to the positive battery post. Double check and thoroughly clean that positive cable clamp. Mine looked ok but upon further inspection it had a slight film of hardened corrosion (almost opaque) all around the inside of the clamp. I had to really scrub it with sand paper, I didn't have a good file and my battery post/ cable brush was a bit too small to be effective.
Michaelnizami
Jun 28, 2014 12:18 PM
franklips
Mar 14, 2008 06:41 PM
discoverMT
Feb 17, 2008 08:57 AM
GrnRover
Feb 8, 2007 02:41 AM
cassie11
Aug 31, 2006 01:46 AM
