04 Headlamps not functioning properly
on
When I turn on the low beams. The high beam only comes on.
I just installed new headlamps on my 04 Disco. When I turn the switch, the driver side low beam does not come on. When I turn on the high beams - all four lights -low and high on each headlamp turn on. Therefore, all the light bulbs work. Whats wrong with the drive side headlamp
they worked fine the first day Installed the new headlamps. Should I try reconnecting the lamp?
Also, I noticed that the interior dash lights don't work right either. When I turn on the headlamps- low beam, the dash lights turn off ( faded- not completely off). When I turn off headlamps, the dash lights turn on a brighter green. The opposite of what it’s supposed to do.
Regarding the other issue, was the Hi/Lo working correctly before you replaced the lamps?
on
