04 no diff lock?
Old Sep 26, 2014 | 09:01 AM
  #21
abran's Avatar
Originally Posted by stb616
Says 06/01...I thought it was just the 02's but oh well. It's a one owner with only got 56k on it which is why I wanted it. I'll prob leave it alone for a while. I'll just grab one with a cdl when I find a good deal on it and save it for a rainy day.
And you are 100% positive you don't have it? I guess it's true... You can't believe everything you read on the internet.
Old Sep 26, 2014 | 10:12 AM
  #22
stb616's Avatar
I'm pretty sure I don't. Am I correct that it's on the front, top of the TC....towards the center of the vehicle?
Old Sep 26, 2014 | 10:46 AM
  #23
abran's Avatar
Refer to page one of this post. TriarII shows the locking nipple on the right photo. Try to use a smart phone,as suggested, to get a glimpse on the top of the T case, or feel around. I found that if you don't know what you are looking for, the feel around technique is not so great.
Its worth it to make 100% sure you don't have it before giving up.
Old Sep 26, 2014 | 11:36 AM
  #24
TRIARII's Avatar
Originally Posted by Sarge103
Is the nipple what the linkage is attached to? and do lubricants such as pb blaster have any affect loosening it up since its cable actuated?
My linkage was not completely stuck. I was able to engage the hi/low range, just could not shift to the left to engage the diff lock. Are you able to engage the hi/low aspect of the linkage? or is the entire shifter stuck so you could not move it at all? As for the lubricant I WD-40. I first removed the shifter **** and the boot, then carefully pulled up the foam piece then applied lubricant in that hole that you took a picture of. I did not remove the plate or drill out the rivets. Then i went underneath the truck and applied more WD-40 all around the nipple and saturated as much of the linkage as I could reach using the stray. Solved my issue, however one member on here suggested against using WD-40 on this particular application. I dont know, some people say do this and other people say dont do that.....
Good luck and cheers
cornbreadj
Dec 27, 2014 07:50 PM
dusty1
Dec 7, 2014 01:57 PM
garover
May 8, 2009 10:33 AM
Disco2Guy
Jun 20, 2008 10:13 PM
Acer
Feb 25, 2005 10:29 PM
