1999 D2 overheating
Old Apr 26, 2013 | 11:26 AM
GROVERDISCO's Avatar
Default 1999 D2 overheating
I have had this truck for about 4 months now and just developed this problem out of the blue. Was driving down town when i felt the truck shutter alittle and the check engine light flashed and then stayed on. The truck then ran fine for a day. Next day light was off then did the shutter again setting off the CEL again, this time started to overheat so i shut it down fast. I suspect that this is an internal leak into the cylinder that is causing the shutter but is small enough to not cause smoke. I also go a nasty smell from under the hood ( coolant into the cat? ) like rotten eggs. Before this event i have had no visible leaks and all fans running well.
1999 Discovery 2, 205000 km CDL, rebuilt front drive shaft, 245/75/16 GY Duratracs
2003 Discovery 2 for parts 300000km
2006 LR3 HSE Sold, and miss
Old Apr 26, 2013 | 02:36 PM
Head gasket leak. Can't really see overheat creeping up because the gauge points at 50% from 130 - 240ish. You want to be 180-200. Have to use a scanner or Ultra Gauge to see real temps. May have coolant loss, white smoke out the exhaust, bubbly gurgle sound under dash, coolant in oil, etc. There is also a $50 test for exhaust gas in coolant.
DIY head gaskets are $300 parts, plus machine shop for heads, two weekends and machine shop inbetween.
Old Apr 26, 2013 | 08:27 PM
jfall's Avatar
Get a scanner and put the codes up.
If you have a misfire code on cylnders
1 or 2 or 7 or 8
that is a head gasket probably.
Other cylinder misfires could indicate more serous sleeve problems with those cylinders.
Or you have just a bad coil or wires going bad.
LowcountryOverland
Jun 20, 2012 09:20 PM
forbin10
Dec 1, 2005 07:55 PM
edthediscoman
Oct 5, 2005 01:58 PM
cowgirl1989
Aug 30, 2005 03:31 PM
bakerww
May 24, 2005 09:35 PM
