1999 LR Disco II
Old Jul 30, 2012 | 03:05 PM
natj's Avatar
4th Gear
Default 1999 LR Disco II
My LR Disco II will crank but not start. It sounds as if it is about to.....battery has been checked. Its strong. Supreme gas has been added..no help. All fuses have beeen checked...none bad. Has anyone had this problem before and/or give me some advice?
Old Jul 30, 2012 | 03:31 PM
bballjames's Avatar
Search this forum. There have been a lot of good posts about this recently. First and foremost I would check your fuel pump to make sure that is working.
Old Jul 30, 2012 | 03:37 PM
Read up on failed crank sensors.
Old Jul 30, 2012 | 04:43 PM
natj's Avatar
4th Gear
Thx for the suggestions...was told it could possibly be fuel pump......wanted to eliminate small possibilities first.
Old Jul 30, 2012 | 04:45 PM
natj's Avatar
4th Gear
How do you check the to see if its the fuel pump.....is it listening for click at the gas pump?
Old Jul 30, 2012 | 05:06 PM
jafir's Avatar
It's hot outside in most parts of the country. Do what Mike said.... check for spark, and if you don't have it, replace your crank sensor. About $60 at autozone.
Old Jul 30, 2012 | 05:17 PM
jfall's Avatar
you can have a partner turn the key on and off.
Then your job is to be under the Discovery in the rear listening for the fuel pump come on then off.
It will only run briefly until you crank it.
You may not even be able to hear it.
I am not sure.
But, do what MIKE says!!!
Replace the crank sensor.
Old Jul 30, 2012 | 05:53 PM
That is spark or gas, a failing crank sensor can kill either or both.
Old Jul 31, 2012 | 06:15 PM
natj's Avatar
4th Gear
Sprayed ether on and held throttle open..started ....ran......shut off. Think its fuel pump
Old Aug 1, 2012 | 06:07 AM
drowssap's Avatar
"That is spark or gas, a failing crank sensor can kill either or both"
Tim08
Mar 10, 2012 10:05 PM
kpmaho
Mar 30, 2006 09:40 PM
kpmaho
Feb 23, 2005 04:39 PM
kpmaho
kfordric
Feb 22, 2005 04:04 AM
