2 Quick Questions
Old Aug 2, 2013 | 10:51 AM
BCDisco2Lando's Avatar
Default 2 Quick Questions
First:
Which bank is which on a NA Discovery 2, I believe its Drivers side is bank 1 and passenger bank 2
Second:
When I go to start the truck and have the key in the on position but engine off the IACV humms quite loudly, is this correct. I swapped it with another one I had and it does the same.
Thanks
Old Aug 2, 2013 | 10:58 AM
You are correct on the banks, they can also be referred to as bank A or B, A being the drivers side.
Do you have a service engine light on, if so get the code numbers and get back to us.
Old Aug 2, 2013 | 01:19 PM
Thanks Mike
No engine lights at all and pulled no codes. I have 2 o2 sensors (bank A #1 & bank B #1) reading 0.0v and still no engine light or codes and this has me really baffled.
Old Aug 2, 2013 | 01:22 PM
Oh, and if I unplug (while engine running) the o2 sensor which I tried on bank b #1 the reading goes to 0.4v and no light still.
Old Aug 2, 2013 | 03:16 PM
Reading 0.0 volts on the OBDII connected scanner? Or with your volt meter?
Old Aug 2, 2013 | 04:05 PM
OBD2 scanner
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
jwfuller
Jul 22, 2007 08:07 AM
suntattoo80
Feb 14, 2007 09:25 PM
Desertdualsport
Oct 16, 2006 11:21 AM
