2000 Disco II nothing happening at ignition
Old May 22, 2022 | 11:42 AM
Blackhound's Avatar
Default 2000 Disco II nothing happening at ignition
Turn the key and nothing but a clicking noise from the fuse box under the steering wheel, but i can jump my land rover off, it will start and run fine. 12.6 volts to battery, so battery is good. Headlights won't turn on either, and nothing is working when key is turned to accessory. Any clue to what is wrong with it?
thanks
Old May 22, 2022 | 02:08 PM
Harvlr's Avatar
If you can jump it with no issues, the problem is either your battery connections are poor or your battery is weak. A weak battery can still read full voltage but not have the capacity to provide the needed amperage to run your starter.
Old May 22, 2022 | 07:18 PM
Blackhound's Avatar
thanks corrosion on my terminals, i over looked that. Cranked right up.
Old May 23, 2022 | 12:02 AM
JUKE179r's Avatar
Welcome to the forum mate.
Congrats on the quick fix.
Old May 23, 2022 | 12:02 PM
Harvlr's Avatar
Happy to hear it was an easy fix.
montanajack12
Sep 15, 2020 08:44 PM
RobsRover
Apr 13, 2019 03:33 AM
Matt Humes
Dec 16, 2013 09:20 PM
lalala
Aug 1, 2012 01:50 PM
edbar
Jan 1, 2005 09:08 AM
