2000 discovery quits running without warning
Old May 4, 2017 | 12:17 AM
akm1ke's Avatar
Default 2000 discovery quits running without warning
I was driving my 2000 disco 2 today and it just stopped running without any warning. I tried starting it and it would turn over but never fire off. After about 15 minutes it started up and ran great for about 10 minutes then it died again. This went on for about an hour until I left it and got a ride home. Has anyone else experienced this? Any ideas on what it could be?
Old May 4, 2017 | 12:38 AM
abran's Avatar
Crank position sensor.
Old May 4, 2017 | 07:55 AM
mln01's Avatar
Crankshaft position sensor. Classic symptoms. Virtually no doubt about the cause.
Old May 4, 2017 | 10:38 PM
Frank4's Avatar
x2. Best part is that it's super easy install. Unplug, unscrew and reverse to install. Drivers side halfway up. Easily reachable from underneath the truck. The attached diagram is a funny angle but should get you where you need to be. Your local parts store will have this in stock. Good luck dude.
Bosch Crankshaft Position Sensor 0261210158 - Read Reviews on Bosch #0261210158
Attached Thumbnails 2000 discovery quits running without warning-image.jpeg   2000 discovery quits running without warning-image.png
Old Jun 11, 2017 | 06:31 PM
akm1ke's Avatar
Default Crank shaft position sensor.
Crank shaft position sensor was exactly what was wrong with it. Thanks guys for the help! The disco is back up and running.
Alfa75
Nov 1, 2023 06:02 PM
Schloesser
Apr 17, 2011 02:12 PM
dragon_avaloch
Dec 16, 2008 05:49 PM
snowdude
Dec 2, 2008 04:38 PM
FINISHMAN
Jan 25, 2008 04:39 PM
